nuetral safty switch on 86 mustang - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-18-2004, 05:55 PM
85stangboy's Avatar
New Member
IM having more problems since i put the c-4 in im not useing a nuetral safty switch but how can i make the reverse lights light and it think that its in nutreal a buddy said just use switches but i dont know which wires to hook together and what
Old 12-18-2004, 07:41 PM
It is very slack and IMHO kinda stupid NOT to run a neutral start switch. It can be very dangerous.
I am not a late model Ford type of guy but most used to use a ball type neutral switch.
With a little work ...I am sure one could be adapted.
Old 12-19-2004, 06:52 AM
stu stu is offline
What was it out of and what did it go in to?
Old 12-19-2004, 08:51 AM
85stangboy's Avatar
New Member
Not sure what the c-4 came out of it could have been the 67 mustang the guy had up at his house and it is going into a 86 mustang that had a aod
Old 12-19-2004, 09:07 AM
adtkart@aol.com
A C-4 neutral safety switch attaches to the trans case at the shifter linkage. It shound not be a problem to hook up, and should not be ignored. It will operate the BU lights as well as neutral safety.
Don't you have safety inspections there? Here, if it starts in anything but park and neutral, it won't pass. It is a safety item, for the same reason that they require the safety switch on the clutch pedals now.
Old 12-19-2004, 09:33 AM
85stangboy's Avatar
New Member
We have inspection here but if you take it to the right person they baically just slap a sticker on except emmission im having problems with that
Old 12-19-2004, 12:22 PM
85stangboy's Avatar
New Member
Thanks adtkart i found the peice i needed now i just need to get the stuff hooked up i have just one more question where is park all the way forward or back???
Old 12-19-2004, 01:05 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Arizona had vehicle safety inspections in the 1960's. It became so full of fraud the inspections laws were removed.
We enjoy some of the tightest emission testing here though
Old 12-19-2004, 01:29 PM
stu stu is offline
If it's a column shift it's forward.
If it's floor shift it's " backwards"?
Old 12-19-2004, 04:30 PM
85stangboy's Avatar
New Member
Well its a Floor shift but all the way back it does click it just like has a spring loaded thing like the kickdown would what would happen if its first instead of park what would happen
Old 12-19-2004, 05:01 PM
stu stu is offline
I'll probably be sent to the penalty box but here goes.
I'm not sure if you really want that question answered or not.
Old 12-19-2004, 05:35 PM
bud-23's Avatar
Are we having fun yet?
A C=4 with a floor shift, park will be all the way forward. Towards the firewall.
Old 12-19-2004, 07:17 PM
adtkart@aol.com
On a C-4, if the trans linkage points upward, Park is to the rear. If it points downward, park is to the front. The neutral safety switch has a small hole in it. To properly adjust it, loosten both mounting bolts, stick a small item, like a nail in that hole while twisting the switch to align it with the inside hole, then tighten the mounting bolts. I believe this is done in neutral, but it may be park( it's been a few years since i've done it).
If the traqns will not stay in park by itself, there is a problem inside with the linkage.
Old 12-19-2004, 07:41 PM
stu stu is offline
Bud -23 you are incorrect on the position of the lever.
Unless you are talking about the actual shifter itself.
And yes the switch is adjusted in Neutral.
Old 12-19-2004, 08:02 PM
bud-23's Avatar
I must have read something wrong. Yes, I was talking about the shifter. I took a C-4 out of my mustang and put in a toploader 4-speed. Sorry Aaron and Stu.
Norm.
