Numbers on a engine - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-18-2010, 09:37 AM
oldtimercarnut's Avatar
Numbers on a engine
Hi Guys
This one has me confused. Can anyone tell me what the numbers on this front pad are for? ( See attached photos ) They look so large that I am thinking maybe a re stamp for some reason. You can see the I.D code letters to the left of the large numbers. They are J.C. and the motor is a 427 c.c. Has anyone seen numbers this large, about 1/4 inch or more. Thanks for any help.
Old 12-18-2010, 10:30 AM
Is this a partial VIN number of the vehicle that the engine came out of?
Old 12-18-2010, 10:55 AM
I do not think so. There are smaller numbers to the left of the large numbers but the only small numbers and letters I can make out is J C at the end of them. You can see the C in the picture.
Old 12-18-2010, 10:59 AM
No expert, but I would agree that they are a restamp of some sort. To the upper left is the remnents of a real factory stamping (C). From my experience, the factory stampings should like up nearly perfectly straight. They used a stamp anvil that held all the numbers and letters in an even row, not individually stamped.
Old 12-18-2010, 11:34 AM
That is what I was thinking but was not sure. Thought J.C. is the end of the I.D. code. I think this could make it a 1967, L72 427 out of a Vett. But the large numbers threw me for a loop. Why would someone stamp a engine with numbers that mean nothing? At least nothing to me.
Old 12-18-2010, 11:56 AM
sqzbox's Avatar
My pipes are my music
I'm guessing a serial number for a crate engine. Looks pretty clean from what I can see. What's the deal? Yours, someone else's, looking to buy?
Might try looking on the side of the block for a metal plate glued to it with a manufacturer's name. I found two on my small block after I pulled it from a 79 truck. Even though they were blank, upon removal I discovered the manf. name and serial number on the backside. I guess it was done that way to protect the name and numbers from the elements. I got the name, looked them up on the web, called them and found all the info I needed on the engine. Maybe you can get lucky like I did.
Old 12-18-2010, 02:05 PM
Wish I could be that lucky to find all the information on it. But the only thing on the side is the date code. 2-28-67 or 68,69 it is to hard to read. I bought this motor this summer and after some work to it placed it in my 1967 Camaro. I do not know how they stamped create motors back then. Do you think there is a way to check create motor numbers?
Old 12-18-2010, 08:47 PM
sqzbox's Avatar
Nix on the # ID. It's realy just a number provided for ID by the manufacturer or builder. Without knowing who did it your in the dark.
Old 12-18-2010, 09:00 PM
sqzbox's Avatar
Update, I googled your #. typed in "engine code 79519C". Apparently your not the only one with this code and it is a 69 427 from what I could tell. Maybe even a COPO engine. Check it out and hope this helps.
Old 12-19-2010, 07:29 AM
I bought the motor from a guy that was going to build a car to place it in. He never got to the project and sold it to me. The best part is he bought it from a guy that said it was a 454 out of a 1969 Camaro he owned. I know the 3963 512 block could be either motor. But when I found the date on the side of the block and not on the back flange I decided to check it internally and it was a 427. I am thinking that the first seller's 1969 Camaro may have been a Copo or Yenko and he didn't know it. After all this took place approximately 20 miles from Canonsburgh Pa. where the Yenko shop was.
Pinging on 03 Chevy 5.3 Engine in Suburban bry21317 Engine 42 10-02-2011 07:35 PM
Knowledge base Dave57210 Hotrodders Site Suggestions and Help 2 12-20-2009 07:06 PM
Engine numbers rodder1 Engine 5 10-26-2009 06:15 AM
383 engine tapping and oil burning- weird RowShan Engine 15 10-10-2009 05:07 PM
engine numbers ? andrewcdennis Engine 3 06-03-2002 08:36 PM
