the numbers on my GM 350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-18-2011, 05:09 PM
The numbers on my GM 350 are V02154AN
Old 12-18-2011, 05:15 PM
chevroletman223's Avatar
Dan The Man
Are you sure of those last two digits? If your looking for a decode, i cannot find "AN" in my book to decode it
Old 12-18-2011, 05:16 PM
Dan The Man
could it possibly be "AAM" instead of "4AN" ? if so it would be a 1976 350 with 160hp stock, hope this helps... -Dan
Old 12-18-2011, 05:30 PM
well....
I'm pretty sure, but I am not goinng to be home until tromarow after noon. I can double check then.
Old 12-18-2011, 05:41 PM
the numbers off the back of the block are
On the drivers side GM 5.7 LO SGT
And on the passenger side 19063938.
If that will help out
Old 12-18-2011, 10:32 PM
DoubleVision's Avatar
The casting number you gave is somewhat confusing, you`ll need to scrub it so you can see it closer. There isn`t a casting that starts in 190 and there`s also no 938 casting.
Old 12-19-2011, 07:04 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
You can pin the block down to what is needed to rebuild it by whether it's a '86-up 1-piece rear main seal block, whether it has a roller cam, or has the threaded bosses and machined lifter bore tops to install a roller cam if it was supplied to you w/a flat tappet. You already know it's a 'LJ' (large journal) 350 and that means it came from the factory as a 4" bore and main saddles sized for the 2.45" main crankshaft journals. Of course the bore needs to be measured to know if it has been previously rebuilt. Sometimes the pistons will be marked on top w/the oversize, like "030, 040, 060", etc.
If you were going to reuse the factory original pistons you'd want to know if the rings were metric or not and if the oil rings were the deep or shallow type.
If it's a 2-piece rear main seal, I don't believe it would have been marked "5.7L". A Gen II will look decidedly different when viewed from the front; the timing cover (if present) is peaked at the top, and if not present there will be enough differences in the water pump gear drive and where the cover bolts up to tell fairly easily.
Old 12-19-2011, 07:29 AM
Thanks
Thank you guys for all the information. I will do some more scrubbing on the block to see if I miss inturprited the numbers. Then I will get back with you
Engine casting numbers and vin numbers drfo Engine 5 06-18-2010 05:15 PM
These Numbers=WHAT? illness Engine 6 07-30-2007 05:36 AM
vin numbers 54rose Engine 1 01-29-2005 08:15 AM
vin numbers jo5hi3 Engine 1 10-02-2003 12:18 PM
Vin numbers 70 nova Engine 2 03-02-2003 05:48 PM
