nut fell in the intake - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-28-2013, 08:43 PM
carb junkie
i was driving home tonight and the not on my air cleaner fell into the carburetor and into the intake. Is it possible that its just on the out side of the valve? i dont think the valve opens enough for the nut to get into the combustion chamber does it?
Old 02-28-2013, 09:00 PM
vinniekq2's Avatar
might still be inside the intake.you would know if it went through the engine
Old 02-28-2013, 09:09 PM
carb junkie
thank you vinnie that puts my mind at ease. lol. but i still wonder.... its making a knockin noise when it runs. could the nut just be bouncing off the back of the valve?
Old 02-28-2013, 09:28 PM
Banned
open the carb wot and with a magnet go fishing..
Old 02-28-2013, 09:35 PM
yep that would be my advice as well. prolly bouncin neer the valve like you origionally posted. it probably wont fit through.
Old 02-28-2013, 09:43 PM
Landshark928's Avatar
FrankenPorsche
If it did get through, pull the spark plugs and again go fishing with a magnet through the plug hole.
Old 03-01-2013, 01:47 AM
1Gary's Avatar
Last journal entry: 383 dyno sym
I think the logical conclusion beyond getting the nut out is how much damage??. A step to take before tearing it down is to scope it,hell scope it to find where the nut is too!!!.
You know the quote:Like in Dirty Harry,you feel lucky today??.
The Following User Says Thank You to 1Gary For This Useful Post:
unclebill (03-01-2013)
Old 03-01-2013, 03:59 AM
poncho62's Avatar
Wiki Edits: 5
Take the carb off and see if you can get it....If you cant, off comes the intake....Better safe than sorry
BTW, if you were driving, how do you know it fell down the carb?....Also, if the air cleaner was on, how could it fall down there?
Old 03-01-2013, 06:53 AM
Pull the carb. If you have an aluminum intake; tie a magnet on a piece of cotton string and fish for it.
If its iron (intake) you'll have to remove it regardless.
Old 03-01-2013, 07:16 AM
Banned
those magnets on the spring hangles do ok even in a iron intake.. I'd try that before I pulled..
at a shop I used to work at (mopar dealer) the tech would put the plug wires on in an odd order hold the carb wot and spin the engine.. the backfire would pitch the nut/socket/etc out the engine..
that goes under don't try this at home.. but flat rate anything goes..
Old 03-01-2013, 07:49 AM
454 Rattler's Avatar
NEVER SATISFIED !!
I have to agree. How could this happen ?
454 RATTLER
Old 03-01-2013, 08:15 AM
Its better to park somewhere when you lose a nut
Old 03-01-2013, 08:18 AM
455olds's Avatar
If you can hear it , it is more than likely a bad thing. Good luck!
Old 03-01-2013, 08:38 AM
Starbuck's Avatar
T how do you know it fell down the carb?
My thoughts too.
If you do need to go fishing for it you can make a pretty good retrieval tool out of some silicone tubing, a small magnet, and some stiff wire. They sell this kind of tubing in hobby shops - folks use it for fuel lines on R/C planes and cars and such. Sometimes these shops also sell small and powerful magnets that are shaped and sized like little BBs. These work really well.
You can stretch the tubing as a tight fit around the magnet so that only a small portion of it remains unshrouded by the silicone. This keeps the magnet from sticking too tightly to any iron, etc. it might encounter and also makes it harder for the magnet to dislodge from your tool.
Cut the tubing to an appropriate length and then slip some stiff steel wire down inside it until it magnetically connects with the back of the magnet. For short retrievers a big paper clip works well but for longer ones an old coat hanger. In a pinch aluminum wire or something non-magnetic can work, though you lose the safety factor of its attraction to the backside of the magnet.
Now you have a pliable tool that you can steer down into various engine passages and to retrieve magnetic parts. It works well for stuff dropped into water jackets, etc.
Good luck!
Old 03-01-2013, 09:11 AM
life is a temporary assignment
IF it did make it into the motor,, It would have to get pass the valves, If the valve happens to catch it.. There is a chance it will hold the valve open and if so, the piston will hit the valve,, The other thing that could happen is, If the nut makes it pass the valve then it will be jumping on top of the piston. Seen this happen to a good friend of mine,, He was changing his plug's and doing a tune up on his honda... Well once he was all done and started it,, He said it locked up on him,, He then called me and said I DON'T KNOW WHAT HAPPEN !!!!
So I went over and looked at it,, He said I only lost one nut going back together with it..
Well I found a piece of nut stuck between the valve and the other piece did a few jump's on top of the piston,, And let me say this.. It did a number on top that piston... Good luck,, Hope you find it..
I think I dropped a 1/2" nut into my intake manifold Steven Pisonero Engine 24 06-24-2010 10:45 PM
Pulley Fell Off 454headache Engine 3 09-09-2009 08:40 PM
not a ford nut or a gm nut either ddwspringer Introduce Yourself 4 07-27-2009 08:05 AM
Help! Piece of Gasket Fell Into Intake... lead09 Engine 11 08-18-2006 08:07 AM
belt fell off? Brian Morency Engine 1 10-11-2004 10:37 PM
