nv1500 350 applications - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-13-2013, 05:33 AM
I have a nv1500 out of a 1999 chevy s10 that I want to put in my gmc k1500 with a older changed over 350. I didn't know what the ratings were for the nv1500 as to whether it would bolt up or not and whether it would hold up to the torque. The tranny was off a 2.2 and the 350 is out of a 80's model chevy
Old 11-13-2013, 07:25 AM
You do realize a trans for a 2.2L 4cyl is not really rated for a V8 duty cycle. A used 4cyl trans behind a V8, assuming you have the right length input etc to install it, is probably short lived
Old 11-13-2013, 07:37 AM
That's what I needed to know so a turbo 400 would be a much better option?
Old 11-13-2013, 03:39 PM
If your choices are TH400 or NV1500 behind a 350, there's no question of which is the better choice (where "better" is defined as: transmission will survive past the end of the driveway). If you want a manual trans, get at least an NV3500.
Old 11-13-2013, 03:51 PM
Thanks yall for the help one more question how much torque give or take can it stand out of a 350
Old 11-13-2013, 08:34 PM
Wiki Edits: 31
The little NV 1500 has been broken by idiots romping the little 4cyls. It will never hold a V8. V8 K1500's usually came with the NV-3500 which is very close in design, but it is much stronger and even the NV 3500 is a bit weak for a 350
Turbo 400 is good to quite a bit of HP in stock form
Old 11-14-2013, 12:47 AM
Marine Applications SGKEMPSR Electrical 4 06-04-2012 01:03 PM
researcing blower applications Dats4me Engine 16 05-16-2011 04:33 PM
Ford EEC-IV Engine Applications 345 desoto Engine 1 09-29-2008 09:46 PM
Are T.R.W. pistons used in stock sbc applications? 85 vette Engine 3 12-18-2004 06:35 AM
