NV3500 5speed & 355 SBC in s10 - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-05-2008, 10:31 AM
I have the New Venture 3500 5 speed behind my 355 engine in a 92 S10.
The engine is basically a stock rebuild (300HP).
The truck doesn't have posi (3.54 axle).
This is the transmission that was in the truck before the swap & it worked flawlessly behind the 4.3 V6.
Will it live behind the 5.7 V8?
I have been using it but am kind of sqeemish about stabbin' loud pedal too much. (That's ok too, I'm still breakin' in the motor.)
Any of you out there with a similar setup?
Old 09-05-2008, 11:26 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
That trans is rated for 300-340 ft lbs of torque and is used in several light trucks..just try it and if it blows on you buy a richmond or other heavier duty trans to replace it..
Sam
Old 09-05-2008, 03:25 PM
I read in one manual that had exploded view that they rated them @ 285 lb/ft tq. Your estimate sounds more accurate but what do I know? I'm definateld not a transmission engineer, I can barely put one of these "puzzles" back together again when I take the main case off.
I have 4 other of the same transmission in the waiting if the V8 should render it useless.
I'll try & keep my foot out of it, but I wont promise...
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
S10 to '49 Olds? grouch Suspension - Brakes - Steering 100 10-22-2010 03:57 PM
S10 5speed to a v8 chevy bellhousing ? fred stockberge Transmission - Rearend 8 06-27-2008 09:27 AM
Coupling S10 tranny to SBC Nightfire Transmission - Rearend 7 06-03-2005 10:59 PM
powerglide vrs turbo 400... sbc 355 Dave Y. Transmission - Rearend 5 11-08-2002 03:34 PM
