Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - nv4500 or 4l80e?
Old 12-28-2009, 10:44 PM
M&M CUSTOM's Avatar
M&M CUSTOM M&M CUSTOM is offline
Wiki Edits: 9
Get nothing less than a 12 inch clutch, and between the Borg & Beck 3-finger pressure plate and diaphram multi-finger type go with the multiple finger one, usually they require less effort to operate and hold the same as the other type.
You should be able to get everything you need for the conversion from the junkyard except a new clutch and associated usual "clutch replacement" stuff, clutch plate, pressure plate, throwout bearing, pilot bushing, and that leave you with just looking for junkyard parts of the flywheel and all the bolts in it, transmission and bellhousing, and clutch pedal and all it's associated hardware, and the hydraulic stuff between the pedal pushrod and slave cylinder in (or on) the bellhousing.
And if you can find it, the earlier ones have a better gear ratio for first gear.
