nv4500 to 700r4 in 95 - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-09-2009, 09:50 PM
I have a 95 Chevy with a 350 and nv4500 tranny. I'm tired of shifting and don't need a granny gear. so i wont to put a 700 in its place. i know i have to get the arm for the TB to hook up the TV cable. as well as a different rad. My biggest concerns are the electronics. Can i just hook the the speedo wires to the 700s speedo pick up, to take care of the speedo and cures control?
Skeeter
Old 10-10-2009, 07:13 AM
SSedan64's Avatar
If the 700R4 has the correct parts to run your speedo you can. I'm not sure what signals the ECM will need.
Speedo parts here.>> http://www.transmissioncenter.net/sp...n_______va.htm
Someone will know what's needed & try the search function at top. This question has been asked a few times & you may find an answer there.
Old 10-10-2009, 07:34 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
you will need a reluctor wheel on the output shaft with 40 teeth on it.. this is the dirt common relutctor wheel.
Also need the correct sensor for 4l60 trans , it should plug in to the harness... OR you may need to buy a repair connector end from GM and splice the wire harness together. I would solder the connections if splice is need.
very simple process here
Old 10-11-2009, 04:57 PM
I have an extra 700 that came from a 90 Astor van. the hook up for the speedo looks just like the one on my 4500. so if it will plug it then all my electronic stuff should work then? like the speedo, the cruse and the anti lock brakes?
700r4 to nv4500 swap anyone ever done it? Chevrolet4x4s Transmission - Rearend 6 10-03-2009 08:11 PM
Question about 700r4 / 4wd in my 95 K10 dbaldie Transmission - Rearend 11 01-20-2009 03:40 PM
95 Z71 700r4 (I think) problem Chevyboy454 Transmission - Rearend 6 04-15-2008 12:34 PM
Putting a 1987 700R4 in my 1982 GMC 4x4... indy_85stariones Transmission - Rearend 12 04-28-2007 02:04 PM
Need advice: 700R4 banging in 1st 360Camaro Transmission - Rearend 11 11-20-2003 06:44 PM
