nx284h lets talk cam and springs - Page 6 - Hot Rod Forum : Hotrodders Bulletin Board
  #76 (permalink)
Old 03-14-2014, 12:19 PM
ss454lemy's Avatar
Originally Posted by 66GMC View Post
Here's another idea.
H581CP $300.00 / set. (Yeah, I know, you still need rings and gaskets, etc)
I get 10.08 compression with 122cc heads ... perfect.
i wish man i really do but im not in the position to right now
  #77 (permalink)
Old 03-19-2014, 05:47 AM
ss454lemy's Avatar
hope fully i build this in a couple days. ill post vid's when i do. i wanted to thank u guys for the info u have given me.
  #78 (permalink)
Old 03-19-2014, 10:20 AM
ss454lemy's Avatar
ok milled the heads and they are at 113cc's what do you guys think ??
is my combo getting any better ?? did a compression calculator and came back at 8.7:1 should be alot better correct? i put +10cc for the dish and valve reliefs...
  #79 (permalink)
Old 03-19-2014, 10:55 AM
vinniekq2's Avatar
make sure your intake manifold still fits
  #80 (permalink)
Old 03-19-2014, 08:28 PM
ss454lemy's Avatar
im really hoping it does. seen a bunch of people get way with it so. im hoping that goes for me too. iv herd there are shims that are for that right?
  #81 (permalink)
Old 03-19-2014, 09:12 PM
ericnova72's Avatar
More for Less Racer
No on the shims. If it doesn't fit it will have to be milled also...both the sides and the ends.
You can get 1/8" thick intake gaskets from Fel-Pro, that may be your best bet.
The Following User Says Thank You to ericnova72 For This Useful Post:
ss454lemy (03-20-2014)
  #82 (permalink)
Old 03-22-2014, 08:54 PM
ss454lemy's Avatar
well everything has been going smooth for now cam swap is done heads on and no milling needed for the intake !!!!
  #83 (permalink)
Old 03-23-2014, 01:47 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
Hmmm, Yeah... Felpro Performance Gasket Catalog (PDF version of applicable pages also attached)
Does list a few .120 thick gaskets, (i.e. #1281-5) but it looks like that part # is designed for adapting a rectangular-port 1.945" x 2.585" aluminum intake manifold to oval port cast heads?
Considerations for choosing the correct gasket:
1.) The OP's heads (049's?) are cast iron, and have 1.82" x 2.05" oval ports.
2.) He also appears to have an (oval-port?) Aluminum intake without an exhaust cross-over.
I wouldn't recommend using the OE replacement (cast-to-cast) gasket (MS902402 open, MS902323 blocked) with an aluminum intake.
I used Felpro Performance #1210 on my 454, which are .060 thick.
HTH.
  #84 (permalink)
Old 03-23-2014, 01:56 PM
ericnova72's Avatar
More for Less Racer
Sorry, my bad didn't realize there aren't many options for Oval port. I'm a Rectangular port guy myself, never seen an Oval port engine that really impressed me on its power output naturally aspirated.
  #85 (permalink)
Old 03-23-2014, 02:04 PM
66GMC's Avatar
No sweat.
Perhaps those 1281-5's may even work?
As long as the gasket is fully enclosed at the intake manifold side?
  #86 (permalink)
Old 03-23-2014, 07:16 PM
ss454lemy's Avatar
felpro is what I have for then intake and exhaust I think for the head gasket too ...
  #87 (permalink)
Old 03-24-2014, 03:23 PM
ss454lemy's Avatar
1.7 roller rockers. how much difference should i expect ???
  #88 (permalink)
Old 03-24-2014, 05:20 PM
ericnova72's Avatar
More for Less Racer
Difference in what?? Are you asking Horsepower?? About 5 hp, due to the roller bearing trunnion instead of ball pivot. No difference in ratio, stock is 1.7 on the BBC, you have to go to 1.75 or 1.8 to get a bigger than stock ratio.
ss454lemy (03-25-2014)
  #89 (permalink)
Old 03-25-2014, 05:18 AM
ss454lemy's Avatar
got cha i thought the motor had 1.6's that why my question... it dose lower friction though correct ?
  #90 (permalink)
Old 03-25-2014, 01:30 PM
ericnova72's Avatar
More for Less Racer
Yes, that is the major advantage, also oil doesn't get heated/burned black so much(lot of hard work for that oil in a sliding pivot like the stock rocker has) and the roller rocker is more accurate on ratio than the generic factory stamped rocker.
ss454lemy (03-26-2014)
lets talk newbie2011 Introduce Yourself 1 12-06-2010 05:38 PM
Lets talk murray fancy Introduce Yourself 3 12-03-2010 05:32 PM
Lets talk about Patriot BMM Hotrodders' Lounge 4 09-06-2008 03:23 PM
More issues....lets talk cam failure TurboS10 Engine 23 09-28-2004 11:51 AM
Lets talk about polishing. 4 Jaw Chuck Body - Exterior 4 12-17-2002 12:53 PM
