Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - O.K., What should I do with the modulator line??
Old 06-25-2003, 05:03 PM
aka Duke of URL
I assume you are working on a PONTIAC and went from a ROCHESTER to a HOLLEY? And there is no manifold port on the HOLLEY?
You will need to source manifold vacuum at the carb, spacer or intake manifold to have the modulator valve work correctly.
