-   -   O.K., What should I do with the modulator line?? (http://www.hotrodders.com/forum/o-k-what-should-i-do-modulator-line-18506.html)
Stinky 06-25-2003 02:31 PM
The modulator valve line is sitting with nowhere to go. I put a 750 Holley carb on my car. Did i miss something or am I missing something on the car??
KULTULZ 06-25-2003 06:03 PM
I assume you are working on a PONTIAC and went from a ROCHESTER to a HOLLEY? And there is no manifold port on the HOLLEY?
You will need to source manifold vacuum at the carb, spacer or intake manifold to have the modulator valve work correctly.
troy-curt 06-26-2003 07:46 AM
your post wasn`t very clear on details,where was it connected
before?:confused:
Stinky 06-26-2003 08:25 AM
Doh,
On the carb somewhere
I have several unused holes that I plugged on the Edebrock Performer intake. I dont know, but I would assume this pulls the same vac pressure. Would it be wise to throw a "nipple" type air fitting on and put the vac line from the modulator valve on that??
Rubberman2003 06-26-2003 01:22 PM
On my car there is a T shaped plastic piece to the left of the engine near the fire wall, mine goes into there and plugs into the tranny. 84 Z28...350 motor
andybird 06-27-2003 04:33 AM
Originally posted by Stinky
Doh,
I recently put a performer intake and edelbrock 600cfm on my chevy, same problem (used to be a rochester), I did exactly what you describe, I used the hole at the back left of the intake
troy-curt 06-27-2003 11:23 AM
It should go to one of the holes on the intake.On chevys it`s right in front of the dist. With power brakes there is a t fitting there; hth;
Troy
