O.K., What should I do with the modulator line?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-25-2003, 01:31 PM
Stinky's Avatar
Suspended
The modulator valve line is sitting with nowhere to go. I put a 750 Holley carb on my car. Did i miss something or am I missing something on the car??
Old 06-25-2003, 05:03 PM
aka Duke of URL
Question
I assume you are working on a PONTIAC and went from a ROCHESTER to a HOLLEY? And there is no manifold port on the HOLLEY?
You will need to source manifold vacuum at the carb, spacer or intake manifold to have the modulator valve work correctly.
Old 06-26-2003, 06:46 AM
troy-curt's Avatar
Shop Owner And Troll Hunter
your post wasn`t very clear on details,where was it connected
before?
Old 06-26-2003, 07:25 AM
Stinky's Avatar
Suspended
Doh,
On the carb somewhere
I have several unused holes that I plugged on the Edebrock Performer intake. I dont know, but I would assume this pulls the same vac pressure. Would it be wise to throw a "nipple" type air fitting on and put the vac line from the modulator valve on that??
Old 06-26-2003, 12:22 PM
Rubberman2003's Avatar
On my car there is a T shaped plastic piece to the left of the engine near the fire wall, mine goes into there and plugs into the tranny. 84 Z28...350 motor
Old 06-27-2003, 03:33 AM
Honorary Redneck
Originally posted by Stinky
Doh,
I recently put a performer intake and edelbrock 600cfm on my chevy, same problem (used to be a rochester), I did exactly what you describe, I used the hole at the back left of the intake
Old 06-27-2003, 10:23 AM
troy-curt's Avatar
It should go to one of the holes on the intake.On chevys it`s right in front of the dist. With power brakes there is a t fitting there; hth;
Troy
