o-rings - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-17-2008, 08:05 PM
o-rings
UPS just dropped of a power steering hose kit I ordered from Speedway Motors.This will hook up a Gm pump to a Ford rack.The rack came with 2 o rings small enough to fit inside.The hose kit has o rings at end of the threaded area.Do i need both to install these hoses? Thanks....
Old 04-17-2008, 08:48 PM
cboy's Avatar
Last journal entry: Finished
My guess is you only need one O ring at each end of the hose.
Always learning...and sharing what I've learned. The Scratch-Built Hot Rod.
Old 04-19-2008, 06:07 PM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
I'm bewildered as to why you guys don't adapt the Ford pump to the Chevy motor and keep everything working like it was designed to do?
It's no big deal to fabricate some brackets.
Old 04-19-2008, 07:33 PM
o-rings
I already had brackets and a gm pump,but thanks for the reply.
Is it possible to stroke a 400 more than it already is? stonedchihuahua Hotrodding Basics 18 11-10-2012 08:27 AM
piston rings please help 67RS-Groundpounder- Engine 6 02-08-2009 08:15 PM
Gapless Piston Rings - Do I Need Them? leejoy Engine 13 12-31-2007 06:37 AM
Need More Info On Piston Rings Canadian Charlie Engine 1 02-25-2006 05:00 PM
piston rings crshrmn3 Engine 3 09-27-2002 11:06 AM
