O2 sensor heat question
I am going to instal a TBI fuel injection on my inline 6 250ci Chevy engine. I have read several times that an O2 sensor with a heater is better because it starts working faster.
If I use a heated O2 sensor, is it heated all the time the engine runs, or does it cycle? If it is not heated all the time, how does it work to turn it on and off? How much current does it use? I need to know where to wire it, relay or not... Or should I just go for the simpler 1-wire sensor? I will be using aftermarket cast-iron headers. Thanks! |
Three wire heated O2 sensor, 12-volts supplied to it while the ignition is on (all the time), not sure of the fuse rating but I cannot recall a relay being used so it would be likely 10 amps or so, maybe less.
IIRC the resistance of the heater is around 5 ohms, so it each heated O2 should pull around 3 amps each. 14.5 volts divided by 5 ohms = 2.9 amps.
a 10~15 amp fuse should be fine. |
Thanks for these great answers!
Randy_ho, I was wondering about the cycling of the sensor because the TBI pcm I have does not have this function, it comes from a vehicle which had a 1-wire sensor. |
do you know what year/model car it came from? Some PCM/ECUs did have the functionallity for the 4 wire, just no connection. You may be able to still use it. I have seen some posts on other forums that others are able to convert from 1 wire to four just by making simple connections. Sounds like you may be able to just connect to one of the pins in the PCM connector and tap into the green signal line from the TPS.
PCM comes from an '89 Chevy Half-ton. That truck had a 1-wire O2 sensor. As far as know, heated sensors were used only on later vehicles with multipoint fuel injection, not on vehicles with TBI. These vehicle would have a different PCM.
wave has a good point there i cant recall ever seeing anything except non heated on TBI engines.
and on some MPI engines instead of one heated sensor(multi wires) there are 2 or 3 non heated(single wire)ones, such as on the 2004 chevy trucks 5.3 and the ford taurus 3.0 1990s and so on.. GM 3800 engines and late model chrysler 4 cyl engines often have the heated sensors we work on these all the time, so commonly, im just trying to help somehow, lol. good luck hmm my name is randy and i am in IL. my dad is also the same name and in this state somewhere.. hmm.. interesting.... lol. maybe i know you? possibly? |
Ok, I think in my opinion, I would go with a 3 wire. Easiest method - 1 wire to the sensing line, 1 to ground, and one to switched power. This will work, just keeping your o2 heated all of the time.
| supercharger.... | 73monte | Engine | 16 | 07-24-2010 10:27 AM |
| 383 stroker | 73monte | Engine | 10 | 12-05-2009 08:02 PM |
| O2 sensor question | oldred | General Rodding Tech | 6 | 11-27-2009 07:36 AM |
| Wideband O2 sensor placement | full mcgillicutty | Engine | 9 | 07-16-2009 11:11 AM |
| nitrous | 69BiRd | Engine | 2 | 11-28-2003 10:33 PM |
