O2 sensor millivolt range ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-20-2006, 07:00 PM
coldknock's Avatar
'00 Mazda Millenia, 2.5L V6
I need to know if anybody knows or has the proper operating range in millivolts for the front oxygen sensor.
Thanks in advance.
Larry
Old 08-20-2006, 07:39 PM
67 Deuce 4 Me's Avatar
Bowtie or Die!
O2 sensor does exactly that....senses oxygen in the exhaust. Normally a fully heated o2 sensor running the engine 2000 rpm should constantly be switching from lean (under 500mv)all the way down to near 0mv, to rich over (500mv) all the way up to 999mv. That would be what you would see on a engine that is running properly. You need to run the engine at 2000 rpm to check this to keep it heated.
Old 08-21-2006, 02:18 PM
78novaman's Avatar
The AMC, FORD, & CHEVY Guy??!!
Last wiki edit: Improving fuel economy
Last journal entry: Finally on the road
What Deuce 4 Me said, normal operating range for upstream (or front) O2 sensors is 0-999mV. I don't know the spec on your car, but I believe you should have a fairly steady 400-500mV at idle and the engine has been running for at least 30 minutes, giving the sensors enough time to heat up.
A reputable shop should be able to hook it up to a scan computer that will flag any bad sensor reading. This is usually $50-$100 vs $150+ at a dealer.
More low/mid range torque for a 454 tb pickup? macx Engine 1 06-26-2005 01:53 PM
O2 fuel injection and simplicity NXS Engine 15 05-24-2005 12:33 PM
Intake rpm range 350 vs 400 brainsboy Engine 2 09-04-2004 11:13 AM
O2 sensor crshrmn3 Engine 2 09-01-2003 01:12 AM
Nairb's Movie Review--open Range NAIRB Hotrodders' Lounge 4 08-24-2003 02:08 AM
