o2 sensor thread size ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-07-2008, 08:02 PM
Vortech 4.3's Avatar
jack of all trades
i think they are all the same. but mine is GM. i think its 11/16 20.
thanx.
Old 04-07-2008, 08:14 PM
jack of all trades
oh. and what size hole to tap ? thanx
Old 04-07-2008, 09:28 PM
Notorious's Avatar
Hot rodder, not street rodder!
18mm x 1.50 thread pitch, same as the larger spark plugs used in older engines. If you've already got an 18mm plug tap, you're all set. If you need to plug one of these holes, an 18mm replacement oil drain plug will fit. Or, you can stick one of those big, old spark plugs in there.
Old 04-08-2008, 07:56 PM
jack of all trades
thanx
holley jet size markzepp820 Engine 2 03-31-2007 10:23 PM
Garage size options 66GMC Garage - Tools 62 02-28-2007 09:32 PM
Is There An Exhaust Size Rule Of thumb To HP Rating? 64nova Engine 10 11-06-2006 11:59 PM
87 Lincoln Rear Caliper Banjo Bolt Size? sonicweb Suspension - Brakes - Steering 2 08-30-2006 01:00 PM
S-10 tail pipe size catscan4free Engine 3 02-23-2004 02:34 PM
