18mm x 1.50 thread pitch, same as the larger spark plugs used in older engines. If you've already got an 18mm plug tap, you're all set. If you need to plug one of these holes, an 18mm replacement oil drain plug will fit. Or, you can stick one of those big, old spark plugs in there.
