Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Obd 2
Thread: Obd 2
Old 01-30-2013, 06:28 AM
dogwater dogwater is offline
Last journal entry: Still running strong
It has 220,000 miles on it.I've replaced the maf sensor,tps,both upper o2 sensors,replaced an relocated the knock sensor,new roller bearing in the disturbutor,new waterpump,timing belt,new plugs & wires.I don't think it has an egr,I'm no sure on that. Crank sensor is some where behind the engine,can't see or feel it. Nissan really stuff this engine in this truck,not easy to work on. The cats are almost in the engine bay also, don't even think about trying to do any work on it when it hot because every thing you touch is steming hot. Any how I get a check engine light that will stay on for a week or two then goes away then comes back.When the light is on it idles rough when in drive with foot on the brake,when the light is off it idles pretty,other wise than that it runs good. Hell I only paid 800.00 for it,but I guess I've put another 800.00 in it. Its my d/d.
