obd1 elimination - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-11-2010, 07:57 AM
obd1 elimination
I have a 1994 chevy k1500 z71 5.7 auto tran. I im putting in a 350 mod with 650 carb,mild cam,headers,after market ing. How do i deal with the obd1 com. trans shifting,fuel & ing & anything Else THANKS FOR ANY HELP
Old 11-12-2010, 12:24 AM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi,
The 94 truck 5.7/350 is a swirl port headed TBI engine, the head takes an intake with a 75* angle on the center bolts, the Edlebrock E3706 for EGR applications or the E2104 for non EGR would work for a 4 bbl carb application. The tranny for 1994. it could be a 700R4/4L60 (I'm not sure about the 4L60E) neither are designed for a mechanical speedo and require a tail shaft modification to drive a mechanical speedo. No computer, you'll need a conventional HEI that will go right in.
Rich
Old 11-12-2010, 07:12 PM
LATECH's Avatar
There was a post in the trans section a few weeks ago by fastorange, where as he described using the 4l60e with a carburated engine. You still need the pcm to run the trans, incidently you can use the electronic speed sensor to run the speedo also.
Your trans is probably a 4l60 E wich is electronically controled. Do your homework before digging in , you may go backwards.
Old 11-12-2010, 08:35 PM
Race The Truck
Last journal entry: Son's Truck
You don't need to dump the TBI to get power. A few mods and your good to go! Moded tbi 450-700 cfm on ebay 230.00 a performance chip 140.00 and a edlebrock 3704 manifold comp cam 252ah-12. stock heads moded My sons mild street build 300 maybe 320HP Go here www.fullsizechevy.com and www.thirdgen.org www.fivestarengine.com on ebay tbi chips ebay! It all smog legal.
Craig
Old 11-13-2010, 09:29 AM
Hi,
If your truck has the 4L60E. The "E" version needs a computer and a bunch of sensors to operate. That's what I meant when I said I wasn't sure if it's the "E" version or just 4L60
Rich
PS here's a link to fastorange's post that was referenced
How To: Using TBI PCM for 4L60E Control.
Old 11-25-2010, 02:15 AM
if you are hellbent on running the carb, the _easiest_ thing to do would be to pull the 4l60e out, and replace it with an older non-electronic 700r4 if you want o.d if you dont' care about having overdrive.. a TH350 is a great choice.
there are aftermarket shift controllers available, but they ain't cheap.
it wouldn't be that hard to build your own manual shift controller for it either since the forward gears are controlled by a series of on/off solenoids.
I know that both solenoids OFF gives you 2nd gear (Failsafe mode, incase something craps out, 2nd gear leaves you with something useful to limp home with)
Gen VI 454- oil cooler elimination powderbill Engine 1 03-25-2007 07:29 AM
OBD1 code 63 & 64, replaced right sensor, "learn disabled"? mike 96 ws6 Electrical 0 11-30-2005 06:40 PM
proper egr elimination layinitdown Engine 1 03-16-2004 04:28 PM
vacum and time obd1 rally4x4racer Engine 8 02-12-2004 07:26 PM
Dashpad elimination in a 66 Mustang Dejavu Interior 1 12-19-2003 07:11 AM
