-   General Rodding Tech (http://www.hotrodders.com/forum/general-rodding-tech/)
-   -   Obd2 (http://www.hotrodders.com/forum/obd2-201641.html)
HATEMAIL72 07-07-2011 08:44 PM
Obd2
A few months back I switched out my interior I am having communication issues as well with the com port. I do have a Bluetooth wifi unit. Is there any program that will let me alter the info that is strored on the computer
thanks
OneMoreTime 07-07-2011 09:19 PM
Moving to General Tech forum..
Sam
Overdriv 07-08-2011 06:21 AM
thanks
What are you working on? A little more information is needed. No mind readers here that I know of.
HATEMAIL72 07-08-2011 08:07 AM
2005 dodge dakota
Blazin72 07-08-2011 08:50 PM
Are you saying your scanner won't read the ECM? Did you check to see if it was disconnected? Blown fuse? It's a different make but I couldn't read the ECM on my Silverado until I learned the cigarette lighter fuse also supplies power for the OBD II port.
LATECH 07-09-2011 07:35 PM
List what changes you have made.
Like did you changed the seats?were they power seats with memory? Heat?
Did you chge the sound system for an aftermarket?
A lot of functions are cotrolled by the body module, and it is control area networked together. some alterations may or may not affect your desired functions of any or all units.
Post more info about what you are trying to do,what unit are you using that has bluetooth, an IPOD or ?
