Obd2 - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-07-2011, 09:44 PM
HATEMAIL72's Avatar
Obd2
A few months back I switched out my interior I am having communication issues as well with the com port. I do have a Bluetooth wifi unit. Is there any program that will let me alter the info that is strored on the computer
thanks
Old 07-07-2011, 10:19 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Moving to General Tech forum..
Sam
Old 07-08-2011, 07:21 AM
Overdriv's Avatar
thanks
What are you working on? A little more information is needed. No mind readers here that I know of.
Old 07-08-2011, 09:07 AM
HATEMAIL72's Avatar
2005 dodge dakota
Old 07-08-2011, 09:50 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
Are you saying your scanner won't read the ECM? Did you check to see if it was disconnected? Blown fuse? It's a different make but I couldn't read the ECM on my Silverado until I learned the cigarette lighter fuse also supplies power for the OBD II port.
Old 07-09-2011, 08:35 PM
LATECH's Avatar
List what changes you have made.
Like did you changed the seats?were they power seats with memory? Heat?
Did you chge the sound system for an aftermarket?
A lot of functions are cotrolled by the body module, and it is control area networked together. some alterations may or may not affect your desired functions of any or all units.
Post more info about what you are trying to do,what unit are you using that has bluetooth, an IPOD or ?
OBD2 to USB cable. Where to buy? weirdbeard Electrical 22 11-09-2013 02:06 PM
OBD2 scanner curtis73 Garage - Tools 2 03-21-2009 07:26 PM
TX smog compliance on OBD2 curtis73 Engine 3 10-08-2008 10:51 PM
dtc's on obd2 Need help understanding. krruzer Electrical 4 04-23-2008 04:12 PM
