Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - OBD2 scanner
Thread: OBD2 scanner
Old 03-21-2009, 06:26 PM
matt167 matt167 is offline
Wiki Edits: 31
just get a Snap on MT 2500 and all the hookups, it'll cost you $100 for the scanner used and $2-300 for everything else.. but you will then have a scanner that will scan nearly anything
You can get the hookups to scan many domesic vehicles and some imports up to about 2004 or so, with OTC monitor 4000's, but there going to run in the $100 range, and then you will need really specific smart chips to scan anything pretty much after 1999. Pathfinder ( covers everything ) 1999 is the latest cartridge available for the 4000, but you can get the smart chip connector to use the Genisys smart chips instead
