ocean proof winch? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-30-2007, 12:44 AM
ocean proof winch?
does anyone have any suggestions for a heavy duty winch(at least 8,000lbs) that wont get destroyed by sea water
Old 05-30-2007, 08:01 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
For severe duty I would go to a hydraulic winch system..Any moisture that gets into the electrics ruins one of those things.
You may have to do some engineering to get a hydraulic installed..
Just my take.
Sam
Old 05-30-2007, 10:42 AM
rust protectant
with sea water there is a lot of rust,and corrosion,what to do in your situation is to try diffrent things!!!,such as using pro-long-to be put in a spray bottle and spray all the outside (rust or rust maybe parts),or use rust doctor,which is a spray or brush on white looking in color.on the inside you can use pro-long on most parts,or go to radio shack for the ele.spray (water restent type),to protect the ele.inside parts,if not you can use marine-type paint and brush it on real thick,to make it last longer if cables are used you can saturate it with wd40 on a every two day bases>>>>>>>>(BOURNE51).
Old 05-31-2007, 02:34 PM
Have you checked any boat dealers near the coast? I'm sure they're people towing their boats to the ocean, and they have to have winches on their trailers. Just a thought.
I did a quick Google search a here's a hand winch rated for 3700 lbs and for saltwater. You could use a snatch block and get 7400 pounds of pull.
http://shop.easternmarine.com/index....categoryID=197
See the last one on the page.
Jamie
electric winch projectjohn Electrical 17 09-19-2006 04:35 PM
Greetings from over the ocean Lange-tim Introduce Yourself 1 07-02-2006 07:16 AM
Fire proof locker??? 86078 Garage - Tools 9 04-03-2006 06:58 AM
f150 wiring for trailer winch antiquecar Electrical 4 09-13-2005 08:19 PM
Theft Proof? dannimo Engine 15 12-04-2003 08:16 PM
