Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - this is odd
Thread: this is odd
Old 05-14-2004, 12:34 PM
USA1's Avatar
USA1 USA1 is offline
Without a thermostat, the coolant does not have enough time to transfer heat away from the engine, also does not spend enough time in the radiator to sufficiently cool the water before it returns to the system. The thermostat also helps regulate how much coolant can flow as well as when it flows.
