odd 327 casting - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-15-2005, 02:06 PM
camino_man's Avatar
go like he11 machine
odd 327 casting
hey again, i got a friend who supposedly has a 365hp 327 from a 68 chevelle or camaro. the casting number on the front of the block is TI023HN. ive never seen a code like this. it has double hump heads on it and a cast iron four barrel intake set up for a q-jet i guess.the oil filler is at the front of the intake so i know its a little older. im thinking of buying it off of him but i want to make sure of what it is first. any help is appreciated, thanks
Old 04-15-2005, 02:10 PM
dei8fan's Avatar
Registered Brain Surgeon
Acording to Hollander: which is usualy correct.
8-350 4BC 300 H.P.
Chev Pass. 69
Old 04-15-2005, 02:13 PM
poncho62's Avatar
Wiki Edits: 5
HN code......
1965 HN 327 t/ign., m/t 375 FI Vette
1968 HN 327 Pwrglide, reg gas - 4 full size/Chevy II
1969 HN 327 tur 350 - - full size
1969 HN 350 tur hydramatic 300 4 full size
Could be a 65-69
Dont see a 365 hp, there.........................
I doubt if it's the FI motor, unless it has had an intake change.....
I'm thinking with the quadrajet, it is a 300 hp...........just a guess.
Maybe look up the block casting # above the belhousing bolts.
Ontario Rodders
Old 04-15-2005, 03:01 PM
GoneNova/406's Avatar
you have to go back to 1965 block casting #3782870,corvette to find the 365,375 h.p ratings but even then the 365 has an HM code.
i have 2 of these motors.
Old 04-15-2005, 06:52 PM
MI2600's Avatar
Member# 3287
I think the SHP engines came with Winters aluminum intakes.
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
Building A 302 Chevy Scorpio Shaping Flow Hotrodding Basics 6 01-16-2007 05:55 AM
casting numbers for 327 fordguyfordman Engine 3 11-29-2004 05:07 PM
74 heads on a 87 block?? punk1c5040 Engine 22 02-17-2004 09:16 PM
327 block and casting #'s OneBad93LX Engine 7 12-05-2003 01:57 PM
