Odd Air Shocks, HELP - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-12-2003, 06:10 PM
Last journal entry: Rear End Disassembly
I have been disassembling my rear end to replace the entire assembly. I took off the air shocks and this is what I saw::
Both measured 22" long. You know how in a shock there is the long rod that goes in and out as you add/subtract air. Well on the right shock, 5" of that rod was showing and the shock measured 22". However, on the right shock, NONE of the rod was showing, and it measured 22". Get what I'm saying? Is this normal or is it time for new air shocks?
Old 12-13-2003, 09:00 AM
air shocks
Its been awhile since I messed with these but there is a small rubber "o" ring where the air line connects to the shock. It could have went bad and let the air out of that shock. Use to be you could buy these "o" ring kits from Advance, Auto Zone, or Pep Boys. Just to be sure I would replace the air line and BOTH "o" rings from the "T" connection to the shock.
Hope this helps
