Odd fish eye question...Need a bit of help - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-15-2011, 10:44 PM
Im painting my plastics for my bike as Im typing this...I am almost done with the 2nd stage (primer sealer) of 4 but ran into an odd problem...I have one fish eye. I am wondering if there is anything I can do with it other than sand down and repaint. I have no problem doing this but I was just wondering if there is a trick that would save me the time of having to repaint the item...
Thanks in advance
Old 04-15-2011, 11:21 PM
did you use a adhesion promoter?
no tricks other than clean with soapy water
dry
clean again
dry
clean again with chemical
flash
dry
then sand
adhesion promoter
dry
seal
dry
sand
clean again
paint
Old 04-15-2011, 11:50 PM
put up or shut up
you can wait till the sealer is sandable but not cured and sand it out and spray a light coat of epoxy over that area and cross your fingers. A light coat of epoxy will help in enveloping the area without it reacting. If you do it within the curing window you can do the repair and paint but you have the risk of the basecoat doing the same thing. If you let it cure, then sand the fish eyes out, scuff all the epoxy, and then spray a light coat of epoxy over that area it will not react with your basecoat guaranteed.
Old 04-16-2011, 07:40 PM
deadbodyman's Avatar
Wiki Edits: 11
I'd just wash of the sealer (before it dries) with thinner or reducer and try it again...very ez and no waiting...
Was it the big fish that got away... pigjamelectric Hotrodders' Lounge 5 12-16-2007 09:22 PM
about fish fish Introduce Yourself 4 12-07-2007 09:50 PM
new fish aceswild1 Introduce Yourself 2 09-24-2007 10:22 PM
anyone got fish? bullheimer Off-Topic 12 01-31-2006 12:02 PM
New fish jimpa Hotrodders' Lounge 2 06-06-2004 11:42 PM
