Odd fix to my assumed lifter tap! - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-18-2012, 04:00 AM
I would of bet every dollar in my pocket that my 350 had either a lifter or exhaust problem, for about two weeks. Just the other he tranny( two speed power glide) slipped a bit so I topped off the fluid and to my suprise the ticking went away. Is that possible that the rattleing I heard may of resinated up from the tranny? The noise was (what I thought) on the drivers side near the valve cover.
Can the low level caused this madness?
Thanks
Old 04-21-2012, 07:23 PM
LATECH's Avatar
Man, that is something I never heard of, but anything is possible.
Have you checked to see if the flex plate bolts are loose?
Old 04-21-2012, 07:25 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
New one for me also.
Cole
Odd question, can you tap on a panel and tell if there is filler on it? MARTINSR Body - Exterior 22 11-09-2011 08:41 AM
Lifter Tick / Lifter Face Wear Question rthjimmy Engine 6 04-19-2010 06:27 AM
Sticking lifter... easy fix? Is that what it is? Chefasaurus Engine 4 07-10-2009 09:29 AM
Motor break in/lifter tap question. RObs71Nova Engine 6 12-15-2004 08:40 AM
Is SC &co. back under assumed names? woodz428 Hotrodders Site Suggestions and Help 19 10-01-2003 03:35 AM
