Odd SBC valve cover problem. - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-17-2008, 06:51 PM
junior stocker's Avatar
First of all, I KNOW, there's a right/wrong way to install SBC valve covers. On the stroker 305 (334) in my truck, all the rocker arms are contacting the inside of the valve covers, both banks. This is on the pushrod side of the rocker arm that's making contact. The valve covers are installed correctly with the notch cutouts for intake runner clearence facing the intake manifold. The cam is a mild RV type cam. Standard thickness valve cover gaskets. Stock ratio rockers. I've replace the valve covers with a more "boxy" pair for added clearence. These valve covers came on a Target Master 350, and there was never a problem on that motor. Anyone have any ideas why this happened? As I said, they were installed correctly according to the intake notches, but it looks like if the were flipped around there would be more clearence. They're in the trash now, but I'm still perplexed. Anyone? Thanks.
Old 12-17-2008, 07:04 PM
DoubleVision's Avatar
You could use the thicker gaskets that give it additional clearence.
Why this happened I don`t know, as SBC valve covers are all the same. I never seen any taller or shorter on either side.
Old 12-17-2008, 07:16 PM
Maybe your baffels got bent down somehow????
Shane
Old 12-17-2008, 07:32 PM
You need the thicker gaskets as mentioned above, or taller valve covers. There's a felpro gasket with two cork gaskets with a metal center.
Proform makes one that is 1/4 inch taller than stock.
Center bolt:
http://store.summitracing.com/partde...5&autoview=sku
Perimeter bolt:
There's covers that are even taller, but may interfere with your acceshese are the shortest tall covers I'm aware of. There's no standard for "tall".
Old 12-17-2008, 07:47 PM
johnsongrass1's Avatar
Race it, Don't rice it!
NOt all cover gasket bosses were cast the same hieght.
Old 12-18-2008, 07:20 PM
valve cover problem
Like I said, I've already replaced the stock valve covers with some aftermarket, more "boxier" covers and no more problem. I'm just stymied.
DoubleVision, if you look at stock SBC valve covers from the "ends" you'll see that they are not simetrical, even the 300 HP 327 factory chrome valve covers I have are this way. Don't know why Chevrolet did this, and it can be rather subtle depending on the style of valve cover (early vs late,or solid vs vented). Of course aftermarket covers have more room all around.
I could have just flipped the old covers around, so the intake manifold notches were facing the exhaust manifolds, but the driver side cover had actually started to leak oil through a crack from the rubbing.
Thanks for all the responses/advice.
Old 12-18-2008, 09:57 PM
Boxier and height are two different things. How tall are these boxier covers? that is the issue.
Old 12-18-2008, 11:36 PM
"boxier" covers
These NEW covers are just cheap, no-name,SHORT, chromed, valve covers. Instead of the "sides" (lenthwise) tilting inward somewhat, they are "straight" up from the mounting rails; "boxier". Stock SBC valve covers have a "tilt" to them that does'nt match side-to-side, and are supposed to mount only one way. You can "accidentally mount them wrong, and have rocker clearance problems, but mine were mounted correctly and still rubbed. I wonder why Chevrolet changed from the staggered mounting in 59', you could'nt install them wrong. Anyway, my problem is solved, but I'd still like to have an idea of why this happened. Maybe being from a Target Master and Hencho in Mexico had something to do with it.
master cylinder interchange runn141 Suspension - Brakes - Steering 7 05-03-2009 06:15 AM
oil squirts out of valve cover tubbedz Engine 6 07-03-2008 06:39 PM
cam question, any truth to this? 406 ss monte Engine 6 03-30-2008 12:28 PM
silicon valve cover gaskets disappointing rapsag Engine 10 05-01-2006 10:12 PM
roller rocker and valve cover clearance 56madmook Engine 5 03-24-2003 03:53 AM
