Odds of finding a junkyard 400 sbc
Hey guys, I'm currently doing my first serious project, a complete redo of a 1978 Chevy nova. I pulled its running 250 I-6 so that I could put a v8 in of some sort. I would like to put in a 400 sbc as opposed to a 350 since the extra cubes would be nice and that at least it wouldn't be the billionth 350 swap. however, upon spending hours at my local junkyard, I couldn't find 1 vehicle with a 400. Cars like monte carlos and caprices where completely non existent there leaving me to look through probably 20-30 c/k series trucks,blazers, and suburbans and vans. At the end of the day only probably 5 of the vehicles had engines even in them and all were 350's. It's a 150 dollars for an engine at the local yards and I doubt I'm going to be able to find one who sell me a 400 for around that. The cheaper the better since I'm 17 and this will be my first engine build. However, I just can't seem to get over how common the 350 swap will be, I figured the 400 would be a great torque cruiser but it seems like its extinct. Any good suggestions as to where I should look? do I have any shot whatsoever of finding a cheap 400 or should I just pull a plain jain 350? Any help appreciated.
There should be some 400's left in the junk yard. Try some of the smaller out of the way yards that deal in older stuff.Llook at the front balance wheel and if it has a noch out of it about half way around it should be a 400. If you get a choise go with the 2 bolt main over 4 bolt. It's the stronger in the 400. They only made a 4bolt main for a couple yrs. If you cant find a 400 go with a 4 bolt main 350 block you can always build a 383 out of it and be as good as a 400.
Try Craigslist.
alright so what I've found is that the L31 was the last gen of the old 350 small block. It was also named the vortech 5700. It was used in silverado trucks from 1996- to the silverado generation change in around 2000. This appears to be the 350 I would want to find if I went that route. It would already have a roller cam and vortech heads. Potentially allowing me to make a powerful budget motor. Motors in silverado's between 1987-1995 are a gamble. From what I've read the engines did not have vortech heads, and whether or not they were probably setup for a roller is complete hit and miss. Also when looking for silverado's with the vortech car craft says to avoid the cast # 10239906. It has hardened exhaust seats that limit flow supposedly. If anyone can validate this info that would be great.
Would you guys agree that going this route to achieve around 420hp would be much more affordable than a comparable 400 build? Last edited by usaweapon777; 01-08-2012 at 09:14 AM. |
Vortec heads are simple to spot. The intake manifold bolts to the heads with vertical bolts. It was a pretty powerful little engine too. Swap a decent roller cam into it and get an edelbrock performer rpm intake with a holley carb and it will make around 350hp no sweat.
Are you planing a re-build or just a drop-in? Either way start asking about engine milage when your out looking. Also do a little more book investigating and find out how to identify a 4-bolt main engine.
http://car-part.com There are a few with in 250 miles from you,a couple within 100 miles.
Shane |
The engine is going to be rebuilt. From what I've read the only way to know is to pull the pan and look, I'm going to see if casting numbers affect it at all.
2-Bolt Main 400's have 2-Freeze Plugs. I have one 4-Bolt 400 that has the 3rd-Boss but, no Hole/Plug in the center Boss. An oddball. 400 Block Info: http://www.chevytech.info/2c42o4.html http://www.chevytech.info/2c42o1.html http://www.chevytech.info/2c42o2.html 400 Balancer ID: http://www.chevytech.info/2c44o5.html machined out section. |
| mustang odds and ends | Knight_Mare | Interior | 4 | 05-02-2009 04:58 AM |
| What are the odds... | Blazin72 | Off-Topic | 9 | 04-11-2009 02:52 PM |
| Resale value and odds? | LittlePwny | Engine | 4 | 04-10-2009 02:14 AM |
| What are the odds | ChevyThunder | Off-Topic | 3 | 11-03-2006 08:25 AM |
| Brake odds and ends...vendor to buy from? | firstgear | Suspension - Brakes - Steering | 2 | 05-29-2006 08:01 PM |
