odometer problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-14-2009, 02:22 PM
stoney 81ta's Avatar
odometer problems
Hi all have a 81 trans original odometer readings was 152756 kilometers,after changing out my starter motor,my odometer nows read 575674 kilometers any ideas why.Thanks all
Old 09-14-2009, 03:31 PM
ericnova72's Avatar
More for Less Racer
Is this a digital face speedometer/odometer??
Old 09-14-2009, 03:48 PM
No its the analog type
Old 09-14-2009, 03:57 PM
ericnova72's Avatar
More for Less Racer
Virtually impossible for this to happen unless the plastic parts of the odometer are just falling apart/crumbling inside, which is known to happen when they get old. It has nothing to do with the starter unless you were pulling or pushing on the speedo cable while you were installing the starter.
Old 09-14-2009, 06:46 PM
Thank eric,that could most likely be it.
383 stroker problems and ways to fix them leftoverchrisac Engine 15 02-06-2009 06:36 PM
Olds 98 Ignition Module Problems awbazar Electrical 1 01-12-2004 07:42 AM
beater car problems 02 0n 20s Engine 2 11-01-2003 07:53 PM
Light Problems like crazy ponybuster Electrical 7 10-14-2003 01:12 PM
LT1 knocking problems gollygwagen Engine 0 04-23-2003 06:52 AM
