-   -   Oe Posi Numbers (http://www.hotrodders.com/forum/oe-posi-numbers-86127.html)
oldsmo 04-05-2006 06:59 AM
Oe Posi Numbers
Does anyone here have a original GM parts number for a 8.5 28 or 30 spline posi differential case? Any years between 85-88. I believe that the 30 spline will fit right in were the 28 spline was only you would need the axles to go with it correct?
Thank you....
73oldsman 04-06-2006 02:02 AM
Don't know for sure, but this may help
http://www.oldsmobility.com/10bolt-tech.htm
http://www.novaresource.org/axle.htm
oldsmo 04-06-2006 06:04 AM
thanks you
