OEM fuse block disassembly - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-24-2005, 09:09 PM
Last journal entry: Suggestions worth sharing
I thought I'd try to use a GM OEM fuse block to wire my street rod project (specifically, I got one off a Cavalier). I've gotten as far as disassembling the fuse block, and have removed the plastic pins that hold the individual connectors in the back of the block. However, I've still been unable to get the individual wire connectors loose from the fuse block.
Is there some sort of special tool required to get those pesky connectors loose? I can't really see in there far enough to tell which side of the connector needs to be compressed, or even to tell the exact shape of those connectors.
Last question, are new connectors that will fit the fuse block readily available? If not, then I guess i'm wasting my time even messing with this style of fuse block, as I really don't want to put splices in each of these wires.
Thanks for any comments.
Old 04-25-2005, 01:19 AM
docvette's Avatar
Wiki Edits: 12
Fuse blocks
Doc here,
Check here:
http://www.painlessperformance.com/w...-fuseblock.htm
For a prebuilt fuse block...you didn't mention what kind of street rod this was going in , so you'll have to read the catalog to match what you need.
Good Luck!
Doc
Photo:21 circuit
Fuse block
Old 04-25-2005, 03:44 AM
aka Duke of URL
Yes, there is a -special tool (several actually)- to release the tabs to allow the terminal/wire to be removed from the connector. The terminal ends themselves are availble either from GM or an assortment is available from -THEXTON-.
Old 04-26-2005, 07:40 PM
Thank you for your comments, guys!
i'm looking for a better 400 s chevy block 406 ss monte Engine 3 08-23-2005 07:48 PM
SBC Block I.D. Casting# confusion 1Fast65Elky Engine 2 10-13-2004 07:44 PM
i need a better 400 sbc block 406 ss monte Engine 5 06-21-2004 11:31 AM
400 small block re"performance"build 78 monte Engine 2 04-19-2003 07:32 PM
