OEM Hurst Shift Lever - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-11-2009, 07:58 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
In the classified ads, I have the parts needed to swap out an AT and install a manual tranny into a 2nd. gen. F-body for cash or exchange for the same parts to fit an 80 Malibu.
What I also need is the shift lever for an OEM Hurst manual floor shifter (either a 3- or 4-speed Hurst lever will fit). It has the spring steel locking arrangement as opposed to a bolt-on lever.
Anyone have a source for one of these levers- Hurst or otherwise?
Old 12-11-2009, 08:49 AM
SSedan64's Avatar
Mount with this type? >> http://www.hurst-shifters.com/hurst-...MP-OE-SHIFTERS
I don't see any clamp style sticks/levers here tho' >> http://www.hurst-shifters.com/s.nl/c...tegory.7326/.f
They may have something if you call as lots of their parts aren't on the site. Site used to have much more listed before B&M bought them out.
Old 12-11-2009, 09:44 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by SSedan64
Yeah, SS64, that would be the one.
Same as you, I didn't see anything on their site.
Good excuse to hit up a few more swap meets!
Actually, I have a handfull of levers that I might could use- IF I had an example to use as a template.
Auto shift lever adjustment Mertz Transmission - Rearend 5 09-17-2007 01:57 PM
Automatic Shift Lever Mertz Suspension - Brakes - Steering 0 08-10-2007 08:56 AM
C4 Shift lever problem BT74 Transmission - Rearend 6 05-07-2006 05:01 AM
Aluminum Powerglide shift lever. shaggy56 Transmission - Rearend 1 10-10-2003 12:02 AM
Where can i buy a hurst shift lever for a 55-57 chevy? Ivanjenkins Transmission - Rearend 2 03-21-2003 05:29 AM
