Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - OEM Primed Bumper Cover primer/sealer?
Old 04-30-2006, 11:05 AM
tommygunns tommygunns is offline
I have done a lot of searching here on the forum but just want to get a clear heads-up on this situation ...
I have done some modifications to this new OEM bumper which required the use of adhesion promoter then Duramix then adhesion promoter again.
I then spot primed the areas with a rattle can (1K) primer..and got it flat and smooth
My questions would be....
- Should I sand the 1K primer off and shoot the bumper cover with a 2K primer?
Then seal it?
Which primer will work on flexible bumper covers?
Could I just seal it up with some Prime N' Seal and go to base coat??
I'll post up pictures as soon as I complete
