OEM or Stainless Steel Fuel Lines? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-11-2008, 08:18 AM
I'm going to be wrenching on the car this weekend.... 64 Impala SS....
I'm planning on working on the fuel lines. A few questions though:
First off, I'm going to run new lines. Should I run OEM or go with Stainless Steel? I found the OEMs for $65 through Classic Industries and the Stainless Steel for $90.
Secondly, how the hell do I remove the lines?!?! Now, the car has been sitting for 25 years so the stuff is pretty damn dirty to say the least however I got the first line loosen, the line leading to the fuel pump however it is snaked through the control arm
Do I have to remove the control arm?
The next line goes through the frame. Is that supposed to just 'slide' out from the frame and is just crapped up?
Old 03-11-2008, 06:16 PM
cope's Avatar
i like 3/8 stainless fuel lines dont have to worry about them rusting out.
i wouldent remove the control arm i would just get it off any way i could than route the new one around it not trew the control arm.
i would think the other one sould just slide out of the frame use some brake cleaner to clean it up than spray some wd40 in there and try and slide it out
Old 03-11-2008, 06:32 PM
Ok, yea, I figure some can of brake cleaner and some elbow grease would be all I need on the middle line however it does seem to have some seals that go around the line.... that are pretty much shot so I will need something in there....
And I will check into re-routing the fuel line in the front. I honestly would rather do it original.... if thats the way it was out of the box, I'd rather keep it that way.
Old 03-12-2008, 03:55 PM
73oldsman's Avatar
I replaced the old corroded ones on my Olds with stainless steel ones a while back. After seeing how much corrosion was in those old fuel lines I think stainless is the only way to go. It can be a bear to get the old lines out so be ready to get dirty! Also it will help if you have access to a local car shops lift to raise the car up enough to work the new lines in from underneath. Of course, that would be a real luxury to most of us 1 car garage mechanics! Good Luck!
Old 03-13-2008, 06:04 PM
Yea, at this point, I'm ***** outta luck for a garage. I'll be wrenchin' on them myself. The first one was a pain and that was just through the control arm!!!! That was the easy one!!!!
We are going to take a stab at it this weekend.
I was a little concerned. I did some research on it and through an old diagram, it looks like there is a clip on the inside of the frame for the line. If so, will the line still slide out or am I going to have to try to unclip it?
Old 03-13-2008, 08:52 PM
73oldsman's Avatar
The lift I referred to was just to give more heigth to lift the car up to work the lines out or back into the car. I replaced the lines myself on my Olds! I can't even imagine how much a shop would charge to replace the fuel lines! Besides, then you would miss out on being able to say "I did it myself". As far as the frame clip goes, is there not an access hole near the clip that you can get at it with a screwdriver and pry and work the clip up while working the line out?
Old 03-14-2008, 08:05 AM
You know man, I was kicking that around in my head. I will have to check. I think think think there is however, the car sat for 25 years, and part of it was outside. There is dirt caked on to holy hell and back. I can't sneeze without getting a faceful of dirt.
I am really going to have to get under there and pressure wash the hell out of the car.
I will get under and survey it. My only concern is the shape of the clip
Hopefully it will work with me.
And yea, I could imagine a shop charging in the upwards of $300 - $350 for fuel lines.... They don't seem too difficult, I just have to factor in the dirt labor
Stainless brake lines, sealing flare fittings problems Ripped Suspension - Brakes - Steering 7 01-30-2008 07:39 PM
Need help building a fuel system. staleg General Rodding Tech 1 05-16-2007 02:13 PM
running new fuel lines? jcarter General Rodding Tech 11 02-28-2006 01:35 PM
curious about supply and return lines for fuel injection novadan Engine 2 10-02-2005 08:48 PM
Carb size to small???? brainsboy Engine 50 08-14-2005 05:04 PM
