Off center rear spring mounting? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-21-2012, 06:52 PM
iceman36's Avatar
Hi
I have a truck leaf spring that has the rear axle mount off center toward the front of the spring.
So I was just wondering if there is a reason for this?
Like better handling, spring wrap or just done to better position its mounting points?
In my case it would be nice to move my front mounting point back a little.
Ice
Old 04-21-2012, 08:32 PM
Ifit aint fix...Don't broke it
Last journal entry: I am ALIVE! 65GTO FRAME OFF
spring
I use any spot on the spring flat area approx 4-6 inches. just center the wheels in the hole and let the big mop flop!!!!!
rear brake lines wheels to rear end center Studedean Suspension - Brakes - Steering 4 12-23-2011 05:38 PM
mounting a rear T or A 15 1/2" spring bighotroddin Suspension - Brakes - Steering 1 07-04-2011 04:42 PM
Spring bolt/mounting pad problem. TurboS10 Suspension - Brakes - Steering 5 03-03-2010 08:24 PM
Leaf spring mounting question flynbrian48 Suspension - Brakes - Steering 2 01-22-2008 10:30 AM
Mounting Details - SBC & Edelbrock Throttle Return Spring wickster Engine 5 03-16-2005 01:22 PM
