Off my head - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-15-2008, 03:35 PM
Off my head
Hopefully this is a relatively simple question, cos I'm looking for that kind of answer ! I have a Goodwrench 350 with a mild cam and 600 Holley. TH350 B&M shift kit and not too fierce converter. (2000 ish)
Car weighs around 900 - 1000 Kg. Today changing the rocker cover gaskets I noticed one of the garter springs (think thats what they're called, sit up under the rubber top hat on the valve stem) broken off and lying in the top of the head. Long story short, after the thought of changing all of them got thinking about replacing the heads. Question is for street/strip use (mainly sreet) what would be a suitable complete bolt on sugestion please. I would obviously like more power but must be streetable. Good idle low/mid range. So I'm not looking for out and out power, well I am but to be real I cant afford that. Must have reliability aswell. Hope someone can advise.
Cheers.
Old 02-15-2008, 04:22 PM
307malibu's Avatar
Have you seen the "Goodwrench Quest" series Chevy Hi Performance did on that motor? They try L98 and vortec heads along with all sorts of other stuff. Check it out online. And good luck!
Old 02-15-2008, 05:15 PM
techinspector1's Avatar
Wiki Edits: 326
For the computer impaired, here's the series.....
http://www.chevyasylum.com/chp/
Old 02-16-2008, 03:07 AM
wow 'The Goodwrench Quest' is so informative. A MUST read for all goodwrench users. Thank you so much.
VW Jetta Cylinder Head Chevy21 Engine 2 02-13-2008 09:04 AM
SBC HEAD QUESTION: Need Help Picking A Head Mustangsaly Engine 10 11-30-2007 01:48 PM
Head Gasket Selection!!! sexypizzaman Engine 2 09-21-2007 09:37 AM
3.8 Ford Head Gasket Questions RCastle Engine 17 04-11-2005 10:14 AM
which head to use? sune Engine 8 03-07-2004 01:44 PM
