Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Off-set Pinion Shaft
Old 05-08-2009, 05:17 PM
red65novawagon red65novawagon is offline
The trans yoke and pinion yoke must be in perfect alignment or you'll have vibration and eventually worn broken parts and alot sooner than you want. The u-joints are intended to run out of plane in a single direction (up and down) if it tries to run in two it will make an eliptical pattern not circular.
