Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Off-set Pinion Shaft
Old 05-11-2009, 11:19 PM
enjenjo enjenjo is offline
If the driveshaft is offset to one side, that would be one angle in a vertical plane. If it's offset up and down that is one angle in a horizintal plane. If it is offset both vertically, and horizontally, it is still one angle, but at 45 degrees to both the vertical, and horizontal, and still measured the same way.
