off site images won't load - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Hotrodders Site Suggestions and Help
Old 03-19-2005, 10:15 AM
cboy's Avatar
Last journal entry: Finished
Jon,
Decided to make this a separate thread from the hyperlink thread. So this is repeating the question I asked there.
Here is the exact text I am inserting into my post, except that I used [] instead of {} around the comands (had to do it this way or it disappeared from this post).
{img}http://deweydort.supremeserver21.com/page7/rawbody2.jpg{/img}
If I put an hr.com address from my photo gallery in there it brings up the photo. But when I used this off site address, it does not. If I put the above off side address directly into the adress (URL) line, it goes to the pic just fine.
(Added with later edit)
Jon, I figured out a work around to get my pics to show in a post...but still can't get them to show when I link up to another web site. So I'd still like to understand what I am doing wrong there.
Dewey
Always learning...and sharing what I've learned.
Old 03-20-2005, 08:37 AM
Jon's Avatar
Jon Jon is offline
Hotrodders.com Administrator
Wiki Edits: 7314
I just tried this one, works OK on my end. If you're still having this problem, try to post a few pics in this thread. Then, I can look at the text of your post and troubleshoot this.
Old 03-20-2005, 10:21 AM
cboy's Avatar
I am attempting to post an off line image on the next line:
Later edit: Image did not appear. Jon, can you access the text, now not visible, that I have inserted above?
Old 03-20-2005, 10:37 AM
Jon's Avatar
Jon Jon is offline
Wiki Edits: 7314
I see the image loaded properly in my screen. Check this setting in your User CP:
Edit Options==>Thread Display Options==>Visible Post Elements==>Show Images (including attached images and images in [IMG] code).
The checkbox for that option should be checked. Let me know either way.
Old 03-22-2005, 06:54 PM
cboy's Avatar
Interesting, I replied to this post earlier...but it never showed up.
Anyhow, yes, I can see the image on my end now too. Don't know what was wrong before or what happened to fix it.
Noob to this site. a73elkyss Introduce Yourself 2 12-07-2004 06:10 AM
what a great site!!! nlmsc33 Introduce Yourself 1 09-30-2004 10:36 PM
How about taking this site a step further? killerformula Hotrodders Site Suggestions and Help 1 09-19-2004 05:38 PM
Searching for help - found this site - Great Site RapidRoy Introduce Yourself 1 09-16-2004 03:50 AM
This site is great. buckethead1 Hotrodders Site Suggestions and Help 1 04-10-2004 08:11 AM
