Offenhauser Port O Sonic intake manifold - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-02-2008, 08:34 PM
I have this manifold in my garage
i was wondering if you guys could tell my something about this manifold, if it is any good ?
This is for SBC and this is a mid raise single plane intake....
best regards...
Old 08-02-2008, 09:29 PM
Jmark's Avatar
A quote from the Offy web site regarding those intakes.
Designed for serious racers.
Offenhauser Port-O-Sonic intake manifolds are designed for competition only. They feature special plenums and runners configured to match the volume of each specific engine, in order to produce maximum power. They eliminate the lean/rich conditions found from runner to runner in most aftermarket manifolds; and they're dyno-proven to increase power across the entire rpm range. Increases can start as low as 2,000 rpm and go as high as 8,500 rpm.
Lots of info if you google it....
Mark
Old 08-03-2008, 04:46 AM
dawg's Avatar
NAVY VETERAN
hands down one of the best manifolds out there!
I been using them for years.
sure they cost more but the extra cost is evident in the gains in performance.
Intake Manifold Gasket Installation - Help leejoy Engine 7 10-29-2007 07:19 PM
intake manifold is messed up, need help picking another 84Z Engine 1 08-21-2007 04:57 AM
Intake Manifold and Carb Ozz1967 Engine 9 12-29-2005 12:34 PM
70's vintage chevy intake manifold ID sabino56 Engine 3 09-25-2005 10:37 AM
Offenhouser 360* duel port intake manifold 66 T-Bird Engine 4 09-07-2005 11:33 AM
