official 37 and 38 Chevy (All GM) car or truck thread - Page 9 - Hot Rod Forum : Hotrodders Bulletin Board
  #121 (permalink)
Old 03-25-2012, 07:11 AM
matts37chev's Avatar
I don't understand?
Last journal entry: this is only a test
hey brandon, I just went through your journal, you are really getting it done over there
I dont ever seem to get anywhere on mine keep up the good work
who did you find for the bolt in wiper motor?
  #122 (permalink)
Old 03-25-2012, 06:12 PM
Vetteman61's Avatar
Last journal entry: Moving my Journal
Thanks Matt. I can't remember who had the bolt in wiper motor. I found it one late night searching for parts and didn't order it. I'm going to have to go back and search for it again.
Brandon
  #123 (permalink)
Old 03-25-2012, 06:41 PM
I don't understand?
Brandon
when you find it again, maybe you could post a link here for me/everyone else
  #124 (permalink)
Old 03-25-2012, 09:10 PM
Vetteman61's Avatar
Ok, will do!
Brandon
  #125 (permalink)
Old 03-25-2012, 09:26 PM
Vetteman61's Avatar
Here's one:
http://www.forwhatyouneed.com/windsh...onversions.htm
Here's another. It seems from the description you can get a bolt in and add intermittent wipers and possibly adapt it to the original switch.
New Port Engineering
  #126 (permalink)
Old 03-26-2012, 12:17 PM
37 Chevy
Hi Brandon, Lookint at your 37 you have my twin. I also have a 37 4 door. I put a Mustang II front end, new leaf spring rear with a Granada rear end and 3:55 gears a 350 crate engine and 700R4 trans. All my underpinnings were from Chassis Engineering. I am to get it back from the paint shop this week and then the fun starts. I noticed you were asking about a bolt in wiper motor. I assumn you are going to 12 volts. I got the diredt bolt in from Newport Engineering www.newportwipers. This is a direct replacement for the original wiper motor and will use your original assembly. Bolt in the motor hook up the wires and good to go. Good luck, Jack
  #127 (permalink)
Old 03-26-2012, 09:10 PM
Vetteman61's Avatar
Hey Jack, that's awesome. Do you have any pictures of your build??
I just got all my braces and mounts bolted up today for mock up. Even though I took great care to try measure as the directions explained, it seems that my IFS crossmember is still 1/8 inch out from my core support. Did you have any issues with things not lining up exactly perfect?
Do you know what kind of backspacing you're going to be using on your wheels. I want to keep an original look so I'm going to go with some aftermarket "hotrod" wheels that look very similar and will have the original style hubcaps.
Thanks,
Brandon
  #128 (permalink)
Old 03-26-2012, 09:52 PM
Vetteman61's Avatar
I may be wrong but from the looks of it I'm going to have to relocate my battery because of my Chassis Engineering transmission crossmember. Where are you guys relocating your batteries?
Brandon
  #129 (permalink)
Old 03-27-2012, 03:07 AM
hi. mine's in the trunk in the right hand corner. it's easy to get at. someone had mounted one on the passenger side firewall, but it made the engine bay look cluttered.
  #130 (permalink)
Old 03-27-2012, 07:34 AM
I don't understand?
batt.
mine will also be in trunk on the right side
however I am putting it there for weight dist.
wipers
I keep getting newport and the mighty wiper confused
  #131 (permalink)
Old 03-27-2012, 10:05 AM
Leakie's Avatar
Battery Location
Hey I have an idea for the battery location, pretty sure it will work, just have not done it yet. I was going to mount mine inside the front fender. There is a lot of open space behind the wheel, just make a bracket that will bolt to the frame. This way you don't need to run those long leads to the rear, you should just be able to remove the front tire and slide the battery out if need be. What do you think?
  #132 (permalink)
Old 03-27-2012, 12:56 PM
spacytracy's Avatar
Last journal entry: New neon sign for the garage
I bought a steel antique picnic basket from the 50s on ebay for cheap, bolted it to the floor in my trunk next to my 50s steel coke cooler. The two look good together and hide all my cleaning supplies, tools and the battery in the basket.
  #133 (permalink)
Old 03-27-2012, 02:22 PM
I don't understand?
I like that idea
  #134 (permalink)
Old 03-28-2012, 08:57 AM
spacytracy's Avatar
battery box and tool box
Hey Matt, I put pictures of my "battery box and tool box" in my project journal. Take a look and see if this will work for you.
  #135 (permalink)
Old 03-28-2012, 09:08 AM
I don't understand?
wow that is very cool
I am afraid mine wont be that nice for a long time
someday
The Official Tube Notching Thread BAILEIGH Garage - Tools 16 01-17-2010 11:03 AM
The Official Tube Bending Thread BAILEIGH General Rodding Tech 40 01-27-2009 11:13 AM
Jon...New T-Shirts, Artwork, Official thread??? Kevin45 Hotrodders Site Suggestions and Help 2 01-21-2009 11:34 AM
The Official make fun of Schintz Thread! WakBordr7387 Off-Topic 10 03-03-2006 05:01 PM
The Official AMP Performance sucks thread... TooMany2count Hotrodders' Lounge 2 08-05-2004 08:24 PM
