Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - The Official Tube Bending Thread
Old 12-31-2008, 08:07 AM
scrimshaw scrimshaw is offline
Last journal entry: More painting pics
Originally Posted by home brew
I've always wondered when and why would you use pipe and when and why would you use tubing?
Pipe is a vessel for carrying fluids. It is made to an INSIDE measurement and this measurement should remain consistent regardless of the outside measurement.
Tube is a structural member made to carry loads and is manufactured to the OUTSIDE measurement and a load rating which will remain consistent.
Technically speaking you should be using tube to build stuff with and pipe to carry the water/brake fluid etc. but that doesn't stop people interchanging uses without a problem if you know the limitations.
