The Official Tube Bending Thread - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 12-31-2008, 09:10 PM
Mike, JD2 has a rotory bender like the 100. I have the model 3 that I finaly converted to hydroulic last summer. Bend some .083 1 5/8" CM manual for a few years and you get worn out. .125" wall mild steel is a breaze after the CM and quite a bit less spring back.
I realy like the bend tech pro software I have been using for about 5 years now. I would recomend it as an add on to anyones bender.
Mike
  #17 (permalink)
Old 12-31-2008, 09:18 PM
BAILEIGH's Avatar
Quality Fabrication Tools
Last journal entry: Some ideas
Originally Posted by powerrodsmike
You guys have alot of nice looking machinery. Is it manufactured here or overseas? The rdb 100 bender looks like it would be the perfect addition to any shop needing an economical manual bender. The ratchet wheel looks alot easier to use than the bar type ratchet that JD2 has. I also like the fact that it can bend on top of the frame, instead of between the frame. My Hossfeld can be set up to bend on top, and that makes a big difference in time spent bending tube to fit.
Later, mikey
Hello Mikey,
All of our tube benders and tube notchers are built right here in Wisconsin. How long have you had your Hossfeld? Those benders have been around since the beginning of time it seems. I have talked with 100's of guys who grew up bending on those machines.
  #18 (permalink)
Old 12-31-2008, 09:19 PM
BAILEIGH's Avatar
Mike
X2
Bend Tech is a must when bending tube.
  #19 (permalink)
Old 01-01-2009, 03:07 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
All should be aware of the SFI Foundation..this group tests and certifies safety gear for the racing community..
http://www.sfifoundation.com/ for more info,,
most of the major race sanctioning bodies subscribe to their program and it should be noted that pipe is not a listed material for roll cages and chassis..so we use tube which is a listed material for that purpose..
I have a JD2 bender (manual) which has proven to be adequate to what I need to do..main reason I have a bender is the fact that there are not all that many people around here that can bend a tube for the individual car builder when one is needed of a certain specification...
Sam
  #20 (permalink)
Old 01-01-2009, 07:06 AM
OHD's Avatar
OHD OHD is offline
Wow, Boy I am glad to see this thread is not about waking up and being able to bend your tube or not....
  #21 (permalink)
Old 01-01-2009, 12:32 PM
powerrodsmike's Avatar
Wiki Edits: 161
Originally Posted by BAILEIGH
Hello Mikey,
I learned on an old Diacro in metalshop in HS, then was using a model 1 hossfeld starting in '85, which was in another shop I worked in, and I built a copy for myself in '91 and built a bunch of dies. Then in '95 I got a good deal a larger model 2 hossfeld with some dies. It has a capacity of 2" with the hydraulic attachment, but I think I am going to make a manual torque multiplier for it with a set of sprockets and large chain. That way I can still bend manually without dissassembling the hydraulic setup.I also have a greenlee hydraulic rotary draw bender, with 1 1/2 dies but need to make or buy some dies for 1 5/8 ,1 3/4" and 2" tube.
I also make my own small tube benders for some of the things I do with SS tube.
A friend of mine had a JD2, and it was a nice machine as well.
I rarely buy anything new, but people ask me about benders and know a little, so I like to keep aware of what's out there.
I like to hear about stuff still being made in the us.
Later, mikey
BE different....ACT normal.
  #22 (permalink)
Old 01-01-2009, 06:22 PM
Later, mikey
You and me too Mike, I have a 51 year old Pexto stomp shear and I did buy my JD2 used with one set of dies (1 1/2") and then it got expensive 1", 1 1/4", 1 5/8", and 1 3/4", degree ring and hyd. conversion. Not all at once as needed for different jobs.
I did a 4130 roll bar in an 86 Corvette today with it and the hyd. pays for itself every time I use it. I mounted it to a 2"X18" piece of steel so the bender is somewhat portable. My shop is small and no mater what something was in the way when you were trying to bend a main loop, not any more, and when you are not using it you can put it the corner out of the way.
Mike
  #23 (permalink)
Old 01-01-2009, 07:34 PM
RPM's Avatar
RPM RPM is offline
World Class ASE tech
What are your thoughts on bending 1" DOM with a .219" wall on a 2" C/L radius? I have a Jd2 bender and they don't offer a die for it. I can make a die, but did not want to go to the trouble of making it to find out that heavy tube won't bend that tight.
  #24 (permalink)
Old 01-01-2009, 07:50 PM
That is a pretty tight radius for that thick tubing.
Mike
  #25 (permalink)
Old 01-01-2009, 11:12 PM
Wiki Edits: 161
IIRC, the minimum centerline bend radius that I could get out of my homemade dies was about 3.5 times the OD of the tube. Anything less and they'd kink.
Later, mikey
  #26 (permalink)
Old 01-02-2009, 02:44 AM
protrabbi's Avatar
rdb300
hi shane
i just managed to get youre model rdb300 here in the uk a couple of weeks ago.
of to give it a try today making a roll cage for an english ford pop.
have used it a bit to do A arms and seams a superb machine.
a lot user friendly than my manuall bender.
a question regarding die raduis.
i have a 1 5/8" 6"clr for doing the cage but did try to bend an offcut of stainless 1 5/8" x 1.5mm wall but as you stated it wrinkled the tube.
what would be the ideal die radius for doing thinwall stainless in 1 5/8".
only ask about that sise as i wouldnt mind doing a set of headers.
to anyone else using any bender the bend tech software is superb.got the se version here.
thanks
wayne
  #27 (permalink)
Old 01-02-2009, 08:03 AM
BAILEIGH's Avatar
Mike
Yes...bending Chromolly on a manual bender gets old after a while. An upper body work out.
  #28 (permalink)
Old 01-02-2009, 08:08 AM
BAILEIGH's Avatar
Hydraulic power is a no brainer after a couple sticks.
  #29 (permalink)
Old 01-02-2009, 12:11 PM
BAILEIGH's Avatar
Originally Posted by protrabbi
hi shane
thanks
wayne
Hello Wayne,
Good to hear from happy customers.
1 5/8" x 058" wall stainless will kink unless you have die set that is at lease a 7.75" CLR (centerline radius) You will not be able to make hearders with your bender. Headers require a mandrel bender.
  #30 (permalink)
Old 01-02-2009, 12:13 PM
BAILEIGH's Avatar
That is an odd application. What are you building?
Are you sure you are measuring your desired CLR correctly?
The Official make fun of Schintz Thread! WakBordr7387 Off-Topic 10 03-03-2006 06:01 PM
tube bending l1o00o1l Body - Exterior 7 05-22-2003 08:04 AM
