Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Offset Brake Pedal Pad
Old 05-10-2013, 09:56 PM
27Tall T 27Tall T is online now
I have a slight problem with the brake pedal in my deuce. Before the car went to the upholsterer there was no problem with the clearance with the pedal pad, steering column and my foot. After the car came back I find that when I push the brake pedal my foot rubs against the upholstery which surrounds the column. Has anybody seen or know where I can get an offset pedal pad? I can't remove/modify the pedal as it is a major job to do so. The frame is a TCI and came installed with the pedal setup. If I can get it to the right by at least 1" or so than I will have a chance of missing the upholstery.
