If everything were perfect and standard size.. .050". But you will probably settle for around .035- .045" and use a small journal rod.
You will not like the cost. I get at least three times the cost of a standard grind. |
Thanks,
I was hoping that would do it. I have some small journal rods but they need reconditioned also. I was hoping to do a budget build with vortec heads but things just keep adding up, like always. What do you get for a standard grind? They charge a bill here in town, a buck sixty to turn one down for a 383. It's a carquest shop though. |
| Offset grinding a crank | brainsboy | Engine | 3 | 11-22-2007 09:33 PM |
| Grinding an 1182 steel crank to small journal size | flyin99 | Engine | 5 | 05-26-2007 08:30 PM |
| use 265 crank for 302/use 262 crank for 312 | denny1977 | Engine | 2 | 01-22-2006 01:02 PM |
| crank grinding | johnsongrass1 | Engine | 1 | 03-11-2005 04:10 PM |
| Scat 9000 crank VS stock 400 crank? | MOORESPEED | Engine | 5 | 03-03-2005 10:54 AM |
