offset pinion???? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-25-2009, 10:55 AM
offset pinion????
What do you guys think about running the pinion offset about 3" in a street vehicle? I bought a Ford Exploder rear to swap into my 1st gen s-10. Overall length is pretty close, but the ford rear is offset 3"....would this cause any problems?
I believe big rigs do exactly this, to cut down on vibrations and to extend the life of the universals, but is it feasable in a street vehicle?
Also, my truck is a longbed, and I have already replaced the 2 piece driveshaft with a looonnng 1 piece that I had made with 4" tube. The only reason I bring that up is the angle (side to side) should be less severe since the span from the trans to the rear is longer....
Old 06-25-2009, 12:39 PM
The u-joints neither know nor care whether the offset is side-to-side or up-and-down. Since every car has an up-and-down offset, the side-to-side doesn't matter either. The only issue is floor pan and frame clearance.
Old 06-25-2009, 01:11 PM
i agree, but I was wondering if the driveshaft spinning on two different angles would hurt the universal....
Old 06-25-2009, 01:27 PM
It's not spinning on two different angles. There's only one offset. It may be straight down, it may be to the right, or it may be at 45 degrees (or some other angle) between the two, but there's only one offset. Since the driveshaft is spinning, the u-joints will see this angle at some point during each rotation of the driveshaft. So long as the trans output shaft and the differential pinion shaft are parallel, the u-joints don't care in which direction they are offset.
Old 06-25-2009, 01:53 PM
ahhhhhh........
that does make sense now.....
Pinion Angles and Driveline Setup for the Street Centerline Suspension - Brakes - Steering 39 03-29-2015 10:02 PM
Setting ring & pinion, chevy 12 bolt BUFFALOBILLPATRICK Transmission - Rearend 10 11-23-2008 09:48 PM
Offset rearend and pinion angle murrsue Transmission - Rearend 5 05-19-2007 06:51 PM
how to determine correct pinion angle upthcreek Transmission - Rearend 2 12-22-2005 08:58 AM
Offset pinion and driveline angle? I nned advice. mike bryan Transmission - Rearend 4 10-25-2004 07:37 AM
