Offset rearend and pinion angle - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-04-2005, 05:36 PM
murrsue's Avatar
Last journal entry: 57 pickup 8.8 rear axle install
57 chev truck. Volare front IFS.
I'm getting ready to set my motor and tranny in place in my frame in order to position them and make motor and tranny mounts. I put a Ford 8.8 rear in back and it has a 2" center offset toward the pass. side. I'm thinking about moving the motor toward the pass. side as well to avoid too much sideways pinion angle. It looks like the distance from u-joint to u-joint will be about 53 1/2". How much should I move the engine over or will the pinion angle be okay if the motor is centered? Also if I have some side to side pinion angle should I go for 0 vertical pinion angle?
murray
Old 02-04-2005, 05:46 PM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
pinion angle
The straighter the vertical the less stress on the drive train. Horizontal angle has to be calculated.
Old 02-04-2005, 05:49 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Re: Offset rearend and pinion angle
It doesn't matter whether you offset the engine and rear end vertically or horizontally, the shafts must be parallel. Pinion angle alone is meaningless, the important thing is that whatever the tranny output shaft angle is, the pinion must match it in the same plane. The cartoon below can be viewed as looking at the drive line from the top, side or any other angle, the principle is the same. The first and second drawings show the acceptable configurations. Both are just fine. The latter two are BIG NO-NOs!!
Old 02-04-2005, 07:07 PM
cboy's Avatar
Last journal entry: Finished
You really don't need to offset the engine/trans at all. A 2" offset over 53" of length is not that wild - especially if you are not going to be racing. When I put a 307 Olds in an RX-7 some years ago, my rear end guy told me that it was actually advantageous to keep an inch or two of offset in the setup.
Always learning...and sharing what I've learned.
Old 02-04-2005, 07:34 PM
murrsue's Avatar
Thanks guys. I knew that the intersecting lines had to be parallel. I was worried that some moderate strain from sideways pinion angle + some strain from some up and down pinion angle might = too much strain. I'll probably offset the motor 1/2"-1" to give me some clearance from the steering box and try for as little up and down pinion angle as possible.
murray
Old 05-19-2007, 06:51 PM
ajbcc2's Avatar
Last journal entry: frankenstude too
my setup has the old drag bars..with the rubber bumper on the top of them facing the spring. I assume these are supposed to prevent the spring from wrapping in the upward direction on acceleration?...but then i read to have the 3-5 deg upward pinion position at home position because of downward drive at acceleration?..?..what gives? does a ford 9" tend to go up or down when you hit it?
