Offset rod end bearings
Does anyone know of a source for offset rod end bearings? I need to move a support bearing for my steering shaft a fraction of an inch and the easiest way would be with an offset bearing. I need it to support 3/4" steering shaft. This is the sort of thing I had in mind, only bigger and made of steel: M3 Offset Short Plastic Rod End (20x)
Thanks for any help. |
try rustys off road they might be able to help or point you in the right direction.
Thanks Big Chevy, I'll try that.
Rusty's was no help. Anyone else have an ideas?
| All times are GMT -6. The time now is 06:26 AM. |
